Showing results for tags 'heat convectors'.
  1. Hello everyone, I have recently installed beha heat convectors 2000W in my house. The convectors have by manufacturer a temperature selector witch i set to the maximum point on every convector. Each of these convectors are powered and controlled (ON/OFF) via Fibaro single switch. To separate the house into heating zones i am using the Fibaro motion sensor to act as a thermostat in every room/zone (and as an alarm) and link the Fibaro single switch of the convectors in every room. The zoning works when the room temperature is lower than what i set in the zone the heat convectors turn on and when it reaches that temperature the heat convectors are set off by Fibaro ( i am using HC2 btw) in the heating panel. I can set manual mode and holiday from my computer. The problem is when i try to set it manually or set holiday mode on my ipad or my adroid phone, it gives me a message saying "Cannot Enable Manual Mode" and "Cannot Enable Holiday Mode". Does anyone know how to solve this problem ? Thank you all in advance
