Showing results for tags 'heating panel not changing'.
  1. Hey, I would like to report and as well ask you guys to test it. I know it is not heating season but still... So the problem I found on heating panel. Basically heating panel works now very fast, I see nice improvement there. But if I want to use eather room thermostat or radiator valve to change the heating temperature, the heating panel ignore that and keeps showing the schedule mode and schedule temperature. In my opinion after the temperature change on the room thermostat (secure srt321) it should change to the manual mode for 2 hours, that is how it worked, right? Could you guys test it for me? And Fibaro, could you have a look at it. I know it is not urgent now, when we have 30 degrees outside, but again, winter will be here in no time and this will be huge issue if the heating starts
