Showing results for tags 'secure srt321'.
Hi All of you, Does anybody have an idea how to connect a secure SRT321 and a Qubino flush on/off thermostat can be coupled? The goal is that the SRT should be the one to set the temperature and the Qubino should switch the electrical floorheating. Meanwhile the Qubino sensor should be able to measure the reached temperature. So f you set the temperature on the SRT to, for example, 25 degrees, it should switch the Qubino to on, if the measured temperature by the Qubino sensor is below the 25 degrees. as soon as the Qubino sensor measures 25 degrees it should switch of and o
- qubino
- secure srt321
Hey, I would like to report and as well ask you guys to test it. I know it is not heating season but still... So the problem I found on heating panel. Basically heating panel works now very fast, I see nice improvement there. But if I want to use eather room thermostat or radiator valve to change the heating temperature, the heating panel ignore that and keeps showing the schedule mode and schedule temperature. In my opinion after the temperature change on the room thermostat (secure srt321) it should change to the manual mode for 2 hours, that is how it work
- 11 replies
- secure srt321
- popp radiator valve
