Showing results for tags 'heatit z-wave thermostats'.
  1. I have been using HC2 since mid August. Mainly to control a number of Heatit Z-Wave Thermostats (electric floor-heating). Each room is assigned to different zones in the heating panel. In the heating panel I have designed time schedules for each zone with different set temperatures depending on time of the day. Lately (3 weeks ago) I have started to observe some very strange behavior. The temperature is set at 18 degrees from 22:00 (10pm) to 05:00 (5am). At 22:00 the temperature starts to fall (I track this using the consumption tab). The temperature continues to fall until 0:00 exactly (midnight) when it bounces back up to 23 degrees. It then maintains 23 degrees until next time the heating schedule shifts to a new set-temp (@11am) Anyone that have experienced this problem? Thoughts and ideas highly appreciated!
