Showing results for tags 'home automation'.
Dear All, I've installed 3 Fibaro Smoke sensors fgsd-002 throughout my home and have them connected to Domoticz; allong with some other zwave devices. Now i am a bit stuck with regards to integrating them in scenes i want to make. Do i have to make virtual switches for them, if yes, which type and how to know you did it right? Are they setup from the factory to send some kind of notification to domoticz triggering what? I suppose many home automators are using the software, also integrating Fibaro sensors? Tips for getting to know the software/tutorials for a non-IT background are most welcome! Cheers, Q
Hello, Am searching for true image automation, i need help to do this. Any body please help me out.,,.............
- 1 reply
- true image
- home automation
(and 4 more)
Z-WAVE Fibaro 1 x HC2 23 x Fibaro Relay FSG221 13 x Fibaro Dimmer FGD211 1 x Fibaro Motion Sensor, GMS-001 3 x Fibaro Contact Sensor FGK101 2 x Fibaro RGBW Controller FGRGBW-441-R 5 x Fibaro Universal Binary Sensor FGBS321 1 x Fibaro Swipe Aeon 1 x Aeon Smart Switch Heavy Duty (9kW) 1 x Aeon Multi Sensor MS5 (currently faulty) 1 x Aeon Home Energy Monitor 14 x Aeon Multisensor 6 Everspring 5 x Everspring Motion Sensor SP102 2 x Everspring Motion detector SP814 TKB 7 x TKB Double Dimmer 1 x TKB Single Dimmer 3 x TKB Double Switch 3 x TKB Single Switch Remotec 2 x ZRC90 scene controllers Philio 1 x Philio Smart Relay (used to power meter and switch 2 equipment racks) 1 x Philio Remote Smart Colour Button SwiidInter 10 x Swiid Inline cord switch Security Siemens SPC Alarm System with full HC2 Integration via SPC Gateway on Dragino Other 1 x Nodon Octan Remote 2 x Aeotec remote Minimote 21 x DS18B20 Temp Probes 4 x Pogo Plug in wall switch Raspberry PI running sonos-http-api 2 x Remotec ZRC-90 Scene Controllers Open Remote Controller for Custom UI's SYSTEM DIAGRAM NON Z-WAVE Sonos & Amps 1 x Play 5 1 x ZP80 2 x ZP90 1 x ZP100 1 x ZP120 2 x Play 3 6 x Play 1 2 x Behringer EPQ304 Europower 300W 12 x BluCube 8” Ceiling Speakers Cameras 4 x Trendnet TV-IP311PI IP Cameras with PoE Network & Power Netgear JGS524S 24 Port Gig Switch 2 x Ubiquiti Access Points (UAP‑AC‑LR) 1 x Ubiquiti Security Gateway (USG) 3 Surge protect APC Power Strips 3 x 24 port keystone (Cat6a/F-conn) patch panels 2 x Netgear 8 port Gig switch Wifi-Texas 8 Port PoE hub (for tablets and some sensors) 350Mb FTTH broadband Global Cache GC-100-12 Global Cache GC-IRL Learner Unit Media, Sources & Tablets Humax Freesat Box with custom firmware Sony BluRay Player Apple TV Gen 2 Apple TV Gen 3 Android TV Box – NPET MXQ Pro TV Box HDAnywhere 4x4 2K HDMI Matrix Synology NAS – DS415Play (8TB) Zxtel NAS NS310 (2TB) Samsung Galaxy Tab 4 7” - Playroom Samsung Galaxy Tab 4 10” - Kitchen Insignia Android Tablet 10” - Landing iPad Gen 2 - TBD (for demopad) iPad Air2 - TBD (for demopad) Global Cache GC-100-12 Network IR 4 x Various TV's (Smart and dumb) Optoma HD27 Projector SAM 133" Electric Projection Screen Insignia Flex 8 Tablet - Living Room
Hi everybody! I would like to get some help from you, experienced guys in Fibaro and home automation systems. I will start with Fibaro project in my house, but in some aspects I can't find solution even after one week of googleing. If anyone here has will to help I will be thankful for that. My problems 1. How I can install 10 IP cameras and connect them on Fibaro HC Lite or HC2, without any issues? Also if you have something to recommend (camera) for night and day vision with good picture quality say so. 2. How can I attach any TV or radio on my Fibaro HC Lite or HC2 without making virtual devices and implementing LUA codes etc.? Is there any other more simple way? I still don't know which kind of TV I'm going to get, but I wouldn't like to be limited in choosing them because of Fibaro. 3. How I can make, that my coffee machine makes me a coffee through Fibaro if it has a lot of functionalities and it is impossible to setup how strong coffee I want or what amount of coffee do I want etc. The only way to do so is just to preset and prepare coffee machine and to turn it off or on when I press some virtual button on my mobile phone. But it can be tricky. 4. How I can run my AC unit and setup its temperature set point through Fibaro? Same story was told for TV, I don't want to use only some of the AC's I want to know some universal solution for all types. Relay module, dimmer, roller shutters, door/window sensors, flood sensors, thermostats etc. are pretty much understandable to me, so with lights, blinds, windows, heating I do not have any particular problems, but with above mentioned....well, yes, I do have Any assistance will be appreciated! Thanks to everyone and if I missed sub-forum, moderators please react Kind regards!
- 11 replies
