Showing results for tags 'home away'.
  1. Hi, Pretty basic question but I have searched the forum (and web) and not been able to find any solution that can help me. I have created a variable, Home_Away with two values; Home and Away. I then built two simple block scenes that says says that if a wall plug is ON it should switch to HOME (and OFF gives AWAY). I have then a ZRC-90 remote controller that puts the wall plug in in on (button 1) and off (button 2) mode. So far so good. I have then tried multiple times and in different ways to build a simple scene that should run and turn on a window light at a certain time when I'm not home (when I'm home I want to control the light myself). I have then built an additional scene that should turn the light off automatically at a fixed time when I'm not home. This doesn't work the way I want it at all... For instance, if the light is off and I put the wall plug in off (Away) mode the light still turns on - I don't want it to turn on until both conditions are met (time and variable). Adding to this is that the scene to turn it off doesn't seem to work either so I guess I'm missing some fundamental part here? Scene to turn on light below: Scene to turn off light below I can also add that my intention is to continue building from this logic to have multiple lightning scenes that only runs when the house is in Away mode. Many thanks in advance for any type of guidance!
  2. Hi New with Fibaro HC2 and I am moving devices over from my old HUB. Everything Ok so far. What I am missing is to have a global variable or something similar to set the house to different modes (home,away,holiday, night) . Then based on that I want to set the scenes or devices on or off to manage them. Am I missing some functionality ?
