Showing results for tags 'variable with scenes'.
  1. Hi, Pretty basic question but I have searched the forum (and web) and not been able to find any solution that can help me. I have created a variable, Home_Away with two values; Home and Away. I then built two simple block scenes that says says that if a wall plug is ON it should switch to HOME (and OFF gives AWAY). I have then a ZRC-90 remote controller that puts the wall plug in in on (button 1) and off (button 2) mode. So far so good. I have then tried multiple times and in different ways to build a simple scene that should run and turn on a window light at a cer
  2. Hi i wanna set a scenes which function is when i first trigger motion sensor and then turn of the light , also when i 2nd trigger motion sensor and then turn off the light , so i use variables with the scenes as attached file . (i already set the variable "movie " as default 0 ) But When i run the scenes at first time , the light always flashing and never stop , how should i use the variable or any command ? Here i describe the scenes as below 1. when motion sensor is breached and variable "movie " = 0 ,then turn on the light and also change the variable "movie" =1 2. when motio
