Showing results for tags 'in-wall'.
  1. I have a Jasco in-wall dimmer (26932). When I go to add it (by selecting or deselecting every option) the device adds and it says configuration finished. But when I go to the devices they all say not configured. It turns off the switch and when motion is detected it turns the switch back on, but the motion does not indicate a breach. It also added two lights for some reason. Does anyone have advise on resolving this issue or should I try another brand of in wall dimmer? I am tired of Fibaro not being able to add all of my devices properly!! HC2 4.600 device is 2” away from antenna
