Showing results for tags 'interval of temperature reports'.
  1. According to the FGK-10x ZW5 Operating Manual : 52. Interval of temperature reports This parameter determines how often the temperature reports will be sent to the main controller Reading that, I assumed that even with a 100% stable temperature, a temperature report would be sent to the Hub every xxx seconds, as specified into this parameter. I set xxx to 14400 seconds = 4 hours, but the Events List shows that I can wait for as long as 6 hours and more before getting such a Multi Level Sensor Report. And this is not the case of some of the reports being accidentally lost, because I have observed multiple instances of this problem. So my question is : do I read incorrectly what Parameter 52 means ? Or does it not work ?? Has anybody observed it actually working ???
  2. Duplicate, please ignore (could not cancel, sorry)
