Showing results for tags 'fgk-10x'.
Found 4 results
  1. Guest
    Error code of FGK-10x
    Dear all, Does somebody know the meaning of the blinking led of FGK-101 ? I do nor read something clear on the doc. It is because i got an issue on one of the three I got and I did not find an idea of what goes wrong. When I set the battery it starts blinkink with short off for 1-2 seconds then stays off. When I set or remove the magnet it blinks three times very fast. When I press TMP for interrogation there is no light ! When i try a reset I got a solid ligh for 2 s but not the reset confirmation. I the magnet is not present then it seems that the led is half-lighted for 1 s before fast blink. A normal FGK behaviour is A TMP press set in wake-up mode with slow blinking led for 5 seconds Three TMP press set the module in association or de-association mode for 5 seconds (fast leds blinking). Setting the battery with magnet and TMP pressed starts reset mode, removing magnets within the led is solid ligh (2 seconds) starts the reset, then remove battery at next power on rest is confirmed by double blink. slowly blinking led means correct inclusion fast blinking led means inclusion error Hoping someone could help
  2. I am having the magnet of one of the door sensors attached to a steel surface and I am facing the issue that the door remains 'open' even the door is closed. Not always but very often. Magnet is about 2 mm away from the sensor when door is closed Is there any issue known if the magnet is attached to a steel (magnetic) surface? If so, how did you overcome the issue?
  3. According to the FGK-10x ZW5 Operating Manual : 52. Interval of temperature reports This parameter determines how often the temperature reports will be sent to the main controller Reading that, I assumed that even with a 100% stable temperature, a temperature report would be sent to the Hub every xxx seconds, as specified into this parameter. I set xxx to 14400 seconds = 4 hours, but the Events List shows that I can wait for as long as 6 hours and more before getting such a Multi Level Sensor Report. And this is not the case of some of the reports being accidentally lost, because I have observed multiple instances of this problem. So my question is : do I read incorrectly what Parameter 52 means ? Or does it not work ?? Has anybody observed it actually working ???
  4. Duplicate, please ignore (could not cancel, sorry)
