Showing results for tags 'led bulb'.
Found 4 results
  1. Good day, folks I’ve got matching MK switches and sockets virtually all round the house now. Just decorated the kids’ bedrooms and hit a slight snag. I’ve replaced the old 60w tungsten bulbs with new 100w equivalent LED lights We have dimmer switches fitted according to Dimming all kinds of LEDs with Video Tutorial, however they aren’t working properly. I suspect because the dimmer switches are old ones rated for old loads. I’ve tried a newer V-Pro dimmer which sort of works, however there are 2 issues – 1) it doesn’t really dim much & 2) the bulb doesn’t appear to get to full brightness, so not ideal. Can anyone recommend a decent dimmer switch for 15w LED bulbs? My preference would be MK but they don’t appear to do one in the normal MK range. Is there anyone have ideas? Thank you in advance!🙂
  2. Hi guys, I am working on a project in which one of the ceilings has 17 GU 10 LED bulbs in it and the problem, as you probably already can predict, is the brand and wattage of the bulbs themselves. I thingk that it will be a must to sepparate the 17 bulbs into 2 circuits but 1 will have 9 bulbs and the other 8. So, one dimmer 2 for 9 bulbs and one for 8 bulbs... Sounds crazy, right? Even though they will be synchronized there will be some delay for the second Dimmer to react, but that is fine, because that is the only option. Even if we know the wattage of the LED bulbs we, for sure, do not know their PF, which you can not find even in the manufacturer's website. Fortunately I have 9 LED bulbs - GE, 5.5W, 380lm, 3000k and i will test them and i hope that even if the PF is like 0.5 (I hope it is above) the Dimmer 2 will handle them. So, any suggestions, tips and tricks are much, much appreciated
  3. Hi! Does anyone know how to use Aeon Labs LED Bulb with Fibaro before official support? I already sent device-template to Fibaro. Thanks!
  4. Does the HC2 support the Aeon Labs LED Bulb? Thx
