Showing results for tags 'led lamp'.
  1. Good day, folks I’ve got matching MK switches and sockets virtually all round the house now. Just decorated the kids’ bedrooms and hit a slight snag. I’ve replaced the old 60w tungsten bulbs with new 100w equivalent LED lights We have dimmer switches fitted according to Dimming all kinds of LEDs with Video Tutorial, however they aren’t working properly. I suspect because the dimmer switches are old ones rated for old loads. I’ve tried a newer V-Pro dimmer which sort of works, however there are 2 issues – 1) it doesn’t really dim much & 2) the bulb doesn’t appear to get to full brightness, so not ideal. Can anyone recommend a decent dimmer switch for 15w LED bulbs? My preference would be MK but they don’t appear to do one in the normal MK range. Is there anyone have ideas? Thank you in advance!🙂
  2. Hi, I have a problem with a set of led lamps that I try to dimerize, them do not turn off completely I have a set of 9 leds lamps, 15Vcc, type dichroic, which dimerize them are not completely turned off, I am dimerizing it with an RGBW channel and the consumption of that channel is about 2.7 A. Can anyone advise me what to do to solve this problem
