Showing results for tags 'linked device'.
  1. Hi. I have a "linked device" Thermostat which is set up as follows: The Thermostat setting are this: Every time the temperature sensor "Ceiling@Office" updates the temperature, the Air-con switches OFF - WHY????? I find this in the history: The Ceiling@Office sensor is clearly above the cooling temperature! There is NO association between the ceiling sensor and the air-con! I can not figure out why this is happening What am I missing here? Any ideas?? Thx for helping
  2. I have a linked device for heating. The temperature sensor is a door/Window sensor with DS18B20 installed. The switch is a FGS-212 single switch. If the mobile app is running and the values actual temp and temp from heating plan changed in the meanwhile the display is not updated. If I go to settings an read the network data , then go back to the see the linked device, all values are shown correctly . greez Olaf
