Showing results for tags 'liwin l25'.
  1. Hello, I'm struggling with the roller shutter 2 to get it working correctly with my Liwin L25 window-drive. I tried to calibrate the shutter using all 3 methods explained in the handbook (manual, using the z-wave, push button). The calibration immediately starts. Depending on the current state of the window (e.g., closed) the shutter correctly opens the window and than close it completely and then stops (it is not opened again as described in the handbook - in neither of the calibration techniques). After the calibration it is possible to open and close the window completely (using on and off commands). However it isn't possible to drive to a certain position (using dim command) - the commands are ignored like described in the case of a failed calibration. I think the calibration failes - but why? Another odd effect: to get the shutter working the motor operation detection value must be set to 1 or zero. All other values have the effect that the motion starts and stops within one second. Any ideas?
