Showing results for tags 'momentary push button'.
  1. Hi All, This is my first post so bear with me. Im currently installing my first Fibaro system. I have wired a momentary push button switch to a dimmer 2 as per the instructions. i.e. sx to the switch and s1 from the switch. It works perfectly from the computer and app. It doesn't work as expected from the switch. i.e. i press and hold to dim and a quick push to turn on/off and it doesn't do anything. Is there something i need to do in the settings for the 'dimmer 2 I am a bit lost Regards Sean'
