FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
Showing results for tags 'momentary switching'.
More search options
  1. Hi, i bought the Fibaro Double Switch 2 Gen5 and a Fibaro Single Switch 2 Gen5 to control my hallway light. I created an Association with Fibaro Single Switch to the Fibaro Double Switch so I could control the Fibaro Double Switch S2 switch from the top of the stairs and from the bottom in my hallway. When the Fibaro Single Switch (The Transmitter) is set to toggle switching (Variable 20, 1byte dec, 1) it works ok, but when I change it to Momentary (Variable 20, 1byte dec, 0) switching It does not work (It does not turn light on or off) it's as if the Fibaro Double Switch does not receive the signal sent to it or ignores it? Thanks for any help Colin
