Showing results for tags 'no switch'.
  1. Hi all my house has Griesser outside blinds (griesser.ch), all of them currently have a RF remote to control them. I want to add voice control via Fibaro Roller Shutter modules + Alexa, and eventually more smartness through a Netatmo or similar. Now my problem is: since all is RF controlled, I don't have switches to add the Fibaro modules. I found the wires going to the motors of the blinds, but they only have 3 lines (green/yellow, blue, brown). Anything you think I can do? Thanks, Markus
  2. Dear All, An idea of having my rollers controlled came up to my mind quite late, so I decided these will be controlled only remotely (there is neither wires, nor switches on the walls, but under wall junction boxes for shutters). Has anyone tried to start it up and successfully controlled without switches? My plan is that they will be controlled by fibaro app, alexa and by some dummy switch relays with programmed scenes. Thanks Maciej
