I received a new HC2 because my oldone died. Thanks for that Fibaro. Sadly without my recovery stick wich a send with my old HC2.
Its a struggle to get everything connected again with my HC2. And it is all fibaro devices!
First reset the device (don't know if this is necessary) because disconnecting from de connected old HC2 is not possible. This is different on every device. Motion sensors, smoke sensors, and wall plug went (after several try's) well.
I have a problem with resetting and connecting my 2x1,5 switch. Besides that you have to build it out to reach the B button. I reset the device with pressing the B button for at least 3 seconds and wait a minute to process the reset. Afther that put my HC2 in adding mode and pus the B button 3 times very fast. No reaction on my HC2. I build out my HC2 and put it within one meter from the swich and tried the reset en add as above. Still no reaction. I repeated the steps maybe 20 times. Slower, as quick as I can, etc. I also tried a reset and pushing the S1 switch without any results. To be shore to have the S1 switch I also tried the reset en S2 switch several times. I tried the above steps with the different checkboxes in HC2 commander for adding devices (secure etc.).
The B botton is working. When I push it one time, I see the attached light go on or out.
Before I open all of my switches I want to know how to reconnect my fibaro switch to my HC2.
Do I forget something or am I doing something wrong?
