Showing results for tags 'not responsive'.
  1. Hi All, Since a couple of weeks my HC3 has developed strange behaviour. I'm not running a big setup. It is mainly used to control lights, but it is also in use as an alarm- and fire detection system. In total I'm running 39 z-wave devices and 19 Hue lights. The first signs of problems come from the Hue integration. HC3 shows the Hue lights as available, but in fact has lost connection to the Hue hub (which has been running for a year without any problems). During the last week I've found this also affects the rest of the HC3 functionality. For instance: this morning our alarm was on, but a door was opened. Only after about 5 minutes the alarm scene started; maybe because the same door was opened again. In the meantime, a couple of lights were switched off and on without any issues. After a reboot, everything is normal again. I'm running 5.140.17 and Hue is on 1.57.1957200040 (last update, as far as I know). Anyway: I'm a bit in the dark here, so I'm turning to the vast wisdom of this forum. Thanks in advance!
