Showing results for tags 'notify me'.
  1. Hope the forum can help me with this. I switched from HCL to HC2. I configured the HC2 as a gateway with HCL as slave. All working fine. Both HCL and HC2 are running version 4.110. On HC2, I created a scene with an interactive push notification triggered by a timer global. However, if I switch on Qubino relays which has a notify parameter in the advanced tab (see screenshot), I receive the notification on my mobile. The source of the notification (on Android phone) is clearly 'HC2'. How is this possible? It took me hours to find the source of the message but could not find any relation. I'm sure no scene is triggered on HC2. No other source type in a scene on HC2 is triggered. As far as I could test it already, also the HC2 scene is running fine and doing the job. This is the interactive push notification created. The content is exactly the same as the notification in the interactive push notification on HCL (I'm migrating scenes from HCL to HC2). But the source is clearly HC2. api.post('/mobile/push', {["mobileDevices"]={149}, ["message"]='Thermostaat staat te lang op. Afzetten?', ["title"]='Thermostaat afzetten', ["category"]='YES_NO', ["data"]={["sceneId"]=11}});
