Showing results for tags 'qubino 24v'.
  1. Dear Fibaro Team When do you expect to take into account QUBINO Flush shutter DC in the HC2 ? I know Qubino is a competitor but you have to think about users... Thanks by advance
  2. I have a HC2 on version 4.551 Been adding Qubino PWM thermostats and struggling to get them to configure properly The second one I added has added correctly and works perfectly (can set a temperature and the temp sensor works and is accurate) All others have been adding as below No temperature sensor (i have checked its been plugged in) and temperature resets itself to 4oC If anyone knows how I can change the configuration or copy the settings of the one that has worked i would be glad! Thanks Warwick
