Showing results for tags 'rf keypad'.
  1. Community, I use a keypad with tags with a Fibaro binary senso to switch mij alarm on and off. Somebody made me a LUA script for that. When I present a tag the alarm will switch on or off. This is the script: --[[ %% properties 245 value %% weather %% events %% globals --]] local startSource = fibaro:getSourceTrigger(); -- 2 streepjes is commentaar fibaro:debug(fibaro:getGlobalValue("Alarmstatus")) if ( ( tonumber(fibaro:getValue(245, "value")) > 0 ) -- keypad activated and ( fibaro:getGlobalValue("Alarmstatus") == "uit" ) ) then fibaro:setGlobal("Alarmstatus", "aan"); elseif ( ( tonumber(fibaro:getValue(245, "value")) > 0 ) -- keypad activated and ( fibaro:getGlobalValue("Alarmstatus") == "aan" ) ) then fibaro:setGlobal("Alarmstatus", "uit"); end fibaro:debug( fibaro:getValue(245, "value")) fibaro:debug(fibaro:getGlobalValue("Alarmstatus")) fibaro:sleep(3500) fibaro:abort() My problem is that I get "too many instances". I guess I need to include the following line: "maxRunningInstances": 2, But I have no clue how and where. Is there anybody that could and would tell me how to do so? It would be highly appreciated!
