Showing results for tags 'samsung smartthings'.
  1. Hi, I have a Samsung SmartThings Hub Sth-eth-200 and a pair of Fibaro wall plugs FGWPE/F-102 ZW5. I had not problems adding the plugs to the network. They are detected and I can see the power consumption and the state (on/off). However, if i try to change the state (on/off) remotely it doens't work. The only way to switch on/off is manually pressing the push button on the plug. So it´s kind of useless. Is this normal? Is there any way to fix this? Regards, Américo
