Showing results for tags 'scene controll'.
  1. Hi, Would like to have a quickapp that would enable me to start or stop a scene with a button. I tried fibaro.scene("execute", {id}) or fibaro.scene("kill", {id}) But it doesn't work and don't stop and restart the scene. The scene i want to trigger or stop is a move detection in a room to start ligne. I would sometime like this automation not being activated and stop from a QA that is controling all room parameter. thanks for the support
  2. Does anyone have a VD that can have several buttons that kan keep a light (or several) on for a certain time, e.g 3 hours, 4 hours etc. Or a suggestion to a scene (preferable block scene) that can do the same. I experience that with so long delay with timer to shut off a ligh in block scene I get problems with "to many instances"
