Dear all,
For over a year I'm working with Fibaro components and all installing easy and working fine.
I'm using Fibaro Home Center Lite (HCL)
I have Fibaro roller shutter-2 (FGR-222) working perfectly with Dooya-DT52S curtain motor using a double momentary switches.
Installation and calibration was literally a 5 minutes job.
Last month I bought a Fibaro roller shutter-3 (FGR-223)
Including the shutter-3 on the HCL (firmware 4.520) was ok, but the parameters in the advanced-tab where not visible and calibration was not possible and using the connected switches didn't work opening/closing the curtains. (same Dooya-DT52S motor and double momentary switches)
I did fully reset the shutter-3 module and excluding more times, accordingly including it again. No succes. Tried this multiple times.
Last week new firmware for the HCL was available, firmware 4.530. I installed that one.
Accordingly I included the shutter-3.
Inclusion was succesfull and yes the parameters where visible on the advanced-tab.
Next step I was quite confident with, the calibration. But after trying over multiple times and with different settings, no succes on calibration at all.
The advanced tab has a "calibration" button, or you can do it by way of the B-button or the switches. Non of them was getting the curtains getting moved for calibration.
I'm 100% sure all is connected (curtain, power, switches) correctly to the shutter-3 module.
The curtain motor does respond when pushing the momentary switches (a long push of 2 secs.), but not in a way it should be.
I've some doubts on this module.
Attached some screenshots showing a couple of parameters of the shutter-2 and shutter-3.
The shutter-2 is clear in how to make settings.
The shutter-3 is (for me) totally unclear how to set. It's like some hex.dec numbers to enter.
Does anyone know this is the correct way of displaying the parameters of the shutter-3?
Meanwhile I'm also in contact with my suppliers helpdesk. No solution till now.
Made rma request for returning the shutter-3, for refund, replair of change to shutter-2.
Not contacted Fibaro directly. Might do later.
Anyone advice on this?
Thanks.
Niels
190901 Shutter V2 en V3 parameters.pdf
