Showing results for tags 'sonos api'.
  1. Hi folks, v1.5 of the api is now available on GIT, (just take the latest master) This version contains a number of fixes and some enhancements including some changes to the clip feature The list can be found here https://github.com/jishi/node-sonos-http-api/blob/master/README.md In previous releases the /SAY/ command could get cut off early before it finished or not play at all especially if you had a long sentence being spoken I have been testing the fix for this in v1.5 over the last few days and it would appear to be resolved Upgrade as follows (if running tha api on a pi with Raspbian image) log into pi (normally pi and then raspberry) rename your existing api directory to node-sonos-http-api-old mv node-sonos-http-api node-sonos-http-api-old Clone the latest api master branch from git and place in new directory called node-sonos-http-api git clone https://github.com/jishi/node-sonos-http-api.git Copy your settings.json file from your old to your new api folder sudo cp settings.json /node-sonos-http-api-old /node-sonos-http-api Download the necessary dependencies cd node-sonos-http-api sudo npm install --production Move back to pi home directory and reboot cd .. sudo reboot The new version of the api should be running and can be checked through a browser if you wish http://<ip of Pi>:5005/<playername>/state enjoy.....
