Hi folks,
v1.5 of the api is now available on GIT, (just take the latest master)
This version contains a number of fixes and some enhancements including some changes to the clip feature
The list can be found here https://github.com/jishi/node-sonos-http-api/blob/master/README.md
In previous releases the /SAY/ command could get cut off early before it finished or not play at all especially if you had a long sentence being spoken
I have been testing the fix for this in v1.5 over the last few days and it would appear to be resolved
Upgrade as follows (if running tha api on a pi with Raspbian image)
log into pi (normally pi and then raspberry)
rename your existing api directory to node-sonos-http-api-old
mv node-sonos-http-api node-sonos-http-api-old
Clone the latest api master branch from git and place in new directory called node-sonos-http-api
git clone https://github.com/jishi/node-sonos-http-api.git
Copy your settings.json file from your old to your new api folder
sudo cp settings.json /node-sonos-http-api-old /node-sonos-http-api
Download the necessary dependencies
cd node-sonos-http-api
sudo npm install --production
Move back to pi home directory and reboot
cd ..
sudo reboot
The new version of the api should be running and can be checked through a browser if you wish
http://<ip of Pi>:5005/<playername>/state
enjoy.....
