FIBARO Home Center App 1.0.0 - release Read more... ×
FIBARO Home Center App 1.0.0 - wydanie Read more... ×
Showing results for tags 'two-way switch'.
More search options
  1. Hi guys, Thanks in advance for your advice. My electrician is about to install my fibaro modules and I was hoping to get him some advice. Is it possible to run 2 separate two-way switches off the single FGS-223? ie, one two-way switch circuit on S1 and another on S2?? I'm not sure if it is possible, as there is only one L and one N connection - or does this not matter? There is plenty on the net about wiring a single two-way circuit, but I can't find anything about wiring 2 x two-way circuits on the one double switch. Is this possible?? If it is possible, can someone provide me with a wiring diagram that I can give to my electrician? Thanks heaps in advance for your help! Regards, Eugene.
  2. Hi, I have 2 light switches on top of each other: - One is part of a two way switch - The other one is a "normal" switch In http://www.zwave-review.com/Anleitungen/Wechselschaltung_Fibaro.php (sorry I've found only a german link) it says I have to define Paramter 13 to 0 to use the switch as a two way switch. The description is for FGS-212, which seems to be a single switch. FGS-222/FGS-223 have two switches (as said I have 2 light switches) - Is it somehow possible to use one switch as two way switch and the other as "normal" switch. Or do I need two FGS-212, one for each of the two switches? Thanks!
