Showing results for tags 'universal binary sensor'.
Found 5 results
  1. Witam wszystkich. Czy ktoś wie jak nazywa się i gdzie mogę kupić wtyczkę najlepiej z kabelkami do czujnika jak w temacie? Proszę o pomoc.
  2. hi this has been happening for a while and i cannot explain it. it has started after the 4.170 update so dont know if its related? i have about 9 UBS which all have been working perfectly fine for a while and only 1 has temp sensors. i have noticed that since the last 4.170 update i am getting intermittent notifications that the sensors are being breached. sometimes they work and other times the dont. there is no pattern and i believe that my mesh network is pretty good and stable as no issues with other devices. (i have a fair few scattered around the house). anyone else experienced this issue?? thanks
  3. I am trying to connect my HC2 to my alarm installation (jablotron 100) by means of the jablotron module JA118N and the fibaro binairy sensor based on attached documentation i found on the credex website. It works but it is unrealiable. Status do not get updated all the time. I first believed that there was an issue with the communication between sensor and HC2. Just to make sure i added a FGS223 in the same room to take advantage of the mesh network. I did a network reconfiguartion for the sensor. All seemed to work ok for a short time but then i got the same issue again: when i put the alarm on the fibaro sensor status was not updated. NO reaction on switching jablotron alarm on or off. In jablotron the PG status is responding correctly. When i did a "read configuration" for the module it picked up the correct status. I would like to understand what is causing this issue and i do not believe it is a signal weakness issue. Has somebody an idea what is wrong here (polling?), anything to test ..... Hoe een Jablotron 100 systeem gekoppeld kan worden met een Fibaro.docx
  4. Hi, Specific Lua question I'm hoping a more experienced member can help with. I have a 3-way momentary switch connected to a universal binary sensor which controls my Hue lights via Logic/Lua. I would like to increment the brightness of the Hue lights when the button is held down, I'm comfortable with the Hue control I just don't know how to increment the value for brightness when the button is held. I've attached a screenshot of the scene that I need to add the functionality to, the brightness value is represented by question marks. Any help would be greatly appreciated. Ryan PS. If anyone would like to know how to trigger a Hue Scene or change the state of a Hue Group I'll post something up.
  5. For the Universal Binary Sensor v1.2 you can connect up to 4 temperature probes. Does this mean that there are 4 different temperatures reported or is an average of 4 reported to the HC2?
