Showing results for tags 'alarm system'.
  1. Greetings, I have a situation with Smart Implant. I would like to connect my Paradox alarm system and I am it next point: - I succeed to connect the smart implant (SI) to the system and arm and disarm the system through the Home Center panel. Basically I powered the SI and use OUT 1 for on/off alarm system. My questions are : 1. what should I do (wiring) in order to see in the Home Center panel if the system is armed or not? 2. what should I do (wiring) in order to get a notification if the alarm is triggered? Thank you very much for your support. Bogdan
  2. I am trying to connect my HC2 to my alarm installation (jablotron 100) by means of the jablotron module JA118N and the fibaro binairy sensor based on attached documentation i found on the credex website. It works but it is unrealiable. Status do not get updated all the time. I first believed that there was an issue with the communication between sensor and HC2. Just to make sure i added a FGS223 in the same room to take advantage of the mesh network. I did a network reconfiguartion for the sensor. All seemed to work ok for a short time but then i got the same issue again: when i put the alarm on the fibaro sensor status was not updated. NO reaction on switching jablotron alarm on or off. In jablotron the PG status is responding correctly. When i did a "read configuration" for the module it picked up the correct status. I would like to understand what is causing this issue and i do not believe it is a signal weakness issue. Has somebody an idea what is wrong here (polling?), anything to test ..... Hoe een Jablotron 100 systeem gekoppeld kan worden met een Fibaro.docx
