Showing results for tags 'virtual devicie'.
  1. Dear fibaro Comunity, I bought two Blauberg VENTO Expert A50-1 W ( http://blaubergventilatoren.de/en/series/vento-expert-a50-1-w ) and I would try to connect to my HC2. This system is connected to wifi and is possible controll it with a blauberg app. Anybody could help me? thanks Simone
  2. Hi @ll, I have floor heating system in HC3 with 8 phisical zone and 6 virtual zone and each zone has own trisensor. To contorl floor heating system according to the temperature I add 6 thermostat into my system. This part is working fine. I would like to create a scene or method to switch virtual thermostat heat mode off and on if I press a virtual button (if I open a window I need only one press instead of 6+ ). Unfortunatelly virtual thermostat can not select as device in scene. Any suggestion?
