Showing results for tags 'virtual thermostat'.
  1. Hi @ll, I have floor heating system in HC3 with 8 phisical zone and 6 virtual zone and each zone has own trisensor. To contorl floor heating system according to the temperature I add 6 thermostat into my system. This part is working fine. I would like to create a scene or method to switch virtual thermostat heat mode off and on if I press a virtual button (if I open a window I need only one press instead of 6+ ). Unfortunatelly virtual thermostat can not select as device in scene. Any suggestion?
  2. I linked it to my CV installation via a virtual thermostat (HC3). I would like to set the hysteresis, does anyone know how? I solved it for now via a scene (higher or lower than...), but that's not really a hysteresis setting.
