Showing results for tags 'wall switch'.
Found 3 results
  1. Hi, I have created a LED lamp spot without a wallswitch. The idea is to control this light remoteless by z-wave. I tried to connect the wires without using the IN1/IN2/IN3/IN4 but it's not working. (I can't detect the z-wave device and it's not responding to the reset button) Do I need a wallswitch to have this up and running or do I need to rewire the IN1/IN2/IN3/IN4 some other way?
  2. Hi, I have installed the Fibaro 2 Dimmer. It is wired up as a 2 way switch, one switch wire going to one wall switch (rocker type) and the other switch wire going to the 2nd Wall switch (all with a natural) then a 3 core and earth strapper from the 1st wall switch to the 2nd wall switch. Fibaro 2 is paired on the network and I can turn the light on and off and dimmer through the ST app or through Alexa. What I am unable to do is to turn the light on with the wall switches. If I turn the light on through ST or alexa I can then turn the light off by the swi
  3. Hello, i had installed a double switch 2 in a two-way curcuit. The function over the Fibaro app and scenes are Ok. But if turn on or off the lights manually with the wall switch there is a delay of reaction/of turning of the lamps of 1 second. Without the double switch there is no delay. Is this a "normal" reaction/restriction with which i have to live or could i change this in parameters of the double switch? Just for info: the double switch is just 2 meters away from the HC2 installed so i think it is not an range promblem. Thank you and best re
