Showing results for tags 'wallmote quad'.
Found 3 results
  1. Hello. Im having trubble with my Aeotec WallMote Quad HC3 is reporting the device is not configured, anyone know how to fix this?
  2. Hi All I’ve just bought an Aeotec Wallmote Quad controller. When I add it to my HC2, I can select what to do when I press or hold any of the four buttons. Nice! But: I want to use it to control a Fibaro Dimmer. The Wallmote has swipe commands that should do this, but I can’t get it to work. Please help!
  3. Hello, I have an Aeotec Wallmote (Quad). Initial problem was the battery was draining in a day or two. Solution was to update firmware. I found a version 1.8 which fixed the battery problem. I now have a new problem – the Wallmote glitches about every three days. The blue LED backlight flashes randomly on and of for about 2 minutes. It eventually recovers. Also a word of warning – If you don’t have an Aeotec Z-Stick you cannot do firmware update. There was no mention of this on Aeotec site. Luckily I had a Z-Stick. Does anybody have the Wallmote working without problems? If so what version of firmware? Thank you
