Goodmorning,
Please help me in the right direction.
I bought a aeotec wallmote (4 buttons) and would like to use this wallmote to turn on / dim a set of lights (two fibaro dimmers 2).
However I get lost in setting associations (endpoint, groups, master / slave / single / multi.
I searched for a good explanation, but I couldn't find helpful documentation.
I looked at
wallmote documentation (groups and controls = https://aeotec.freshdesk.com/support/solutions/articles/6000162392-wallmote-quad-user-guide-)
fibaro e-learning (http://e-learning.fibaro.com/topic/associations-in-version-4-x-2/)
It's not completely clear to me how I configure the associations correctly:
I have multiple 'wallmotes' (wallmote master, wallmote 0 - 4). I assume i have to set the association per wallmote button (device)? e.g. wallmote 1 (at this place the wallmote 1 is not available itself in the associations tab?
You have the M and S buttons (I assume Master and Slave). How do I have to configure this?
You have endpoint 0 and endpoint 1. What exactly is the difference. Is this fibaro specific (in the documentation of the wallmote as well as wallmote / vera UI7 i cannot find this
Shoud i use single or multi? and where can I configure this?
I really appreciate your reply!
Specific tips related to this configuration or if you have good documentation avalaible about setting associations in general on the fibaro (endpoints, groups, M / S, best practices) are appreciated!
Best regards,
Roel
