Showing results for tags 'wired touchpad'.
  1. Hello, New to the forum and seeking advice respecting available touch pads for the RGBW controller. Background: We've been using 5 RGBW controllers in different applications in our house for the past 5 years and are very happy. They are rock solid! We use 3 controllers to control kitchen lighting with a web page that supports about 200 color scenes as well as the built in animations, one controls my front porch aluminum rail lighting and the other a back porch wooden rail lighting. I presently use Indigo as my HA system. I am adding 2 more soon to replace the old controllers for stairs and pathway lighting in the upper hall. When this happens I want to add wired touchpad dimmers to 2 of the RGBW controllers so we have manual control as well. I have looked at the toggle and momentary switch solutions but would prefer wired touchpads . I have searched for many hours and have only found wireless/z-wave types, except for this wired dimmer which is available in single channel as well as 4 channel 0 -10v output. Would this work with the RGBW controller and still allow me to control it with my automation controller? I'm not an electrician but it looks like it meets the electrical spec: Sunricher Touchpad type dimmer If this dimmer does work manually with the RGBW controller while continuing to allow me control via the z-wave controller in Indigo, which parameters should I change to allow this to work? If there is another preferred wired touch pad could you kindly provide the source or link where you purchased it? Many thanks for your advice!
