Showing results for tags 'z-wave+'.
  1. Gregory says "The implant heats up, this temperature is adjustable through the offset temperature options". But where are the offset temperature options? They are not indicated in the Smart Implant manual. I also use a Fibaro "eye" motion sensor with a built-in temperature sensor, and there I could adjust the temperature offset (parameter No 66). I could not find the equivalent parameter no in the Smart Implant.
  2. I am trying to develop a custom handler for an open Z-Wave platform which supports BOTH the old Z-Wave version of the Door/Window Sensor FGK-101 and also the newer Z-Wave+ version (aka ZW5) FGK-101. To do that, I need to reliably differentiate FROM WITHIN THE HANDLER the 2 versions. But there are multiple commands for getting Z-Wave / Device informations, and I just don't know what is the proper one to use and the proper attribute to check to ensure a 100% accurate and robust differentiation : ZWavePlus Info, Manufacturer Specific, Version, etc... Any help appreciated
