Hi
I bought the HC2 and some Danfoss LC13 valves - hoping to get zoned heating.
Realised that I need something to switch the boiler on and off - so got the [secure brand] wireless thermostat and receiver (boiler relay essentially)
This is better - I can control the boiler via the thermostat - and I can also run a heating schedule to switch on the boiler at various times and bring the room to a certain temp.
But it is only the room with the thermostat in which I control.
So - at 9am the HC tells the boiler to switch on and make the room 19C for example. Great - but - what about the other rooms ?
I had wanted to ensure that some rooms were warm in the morning, and others warm at bed time. It seems that the thermostat is controlling the boiler (which of course makes sense) - but am I missing something ?
There seems to way to change the set point of the Danfoss LC13 valves - eg to have the kitchen warm in a morning, and the one in the bedroom to have a higher temp at night - if this were possible then I appreciate that the Secure thermostat ultimately rules boiler on / off, but I was happy to have that in a common area (say the hall) and then control other rooms within that 'heating time frame'
Not sure if this makes sense - not sure I can see the point of the danfoss valves at the moment if I have to adjust them manually. Might as well go back to the manual TRV's I took off a month ago
I can see something might be possible with LUA commands - if so, great. But I just want to check I am not missing something obvious ?
thanks in advance
Si
