Android App
When Android app will be avaible?
Is it possibile to have the .apk of Adroid app to make some test?
Thank you
  • Answers 95
  • Created
  • Last Reply
Okay, 1.0.10 beta english/russian attached.
And language xml's too.
If you want to make other translations, please, use APKmanager from Internet and translate instructions.
Tested on ICS.
20 minutes spent. No warranty, of course. You can use it on your own risk!
Maybe, it can push Fibaro to work...
I tried russian and english - both works well! Thanks for this.
Edit: I translated it into Estonian as well.. if you can include tHis I will appreciate!
Guest dsilletti
Hi, I translated in Italian the xml file, if someone can add this to the apk...
Thanks!!!
Guest giz
APK with Italian and Estonian added.
Please test (i'm not sure in right Estonian language code - "et" or "ee". This version with "et")
Estonian works well
/emoticons/default_icon_wink.gif" alt=";-)" /> Thanks for this... There is some mistakes of spelling (my bad) but will test it alittle and fix everything, so you can replace this.
Can someone tell me what is this mean below battery sign: honoraty seweryny tomasza
Also, I understand this is beta version, but is anyone else in trouble with slow reaction speed? I think apple soft is 10 times faster than android app.
I press the button, it thinks a little, then light goes on, and after a few sec the phone updates the icon... it will take about 10 sec from pushing button until everything is OK
Guest giz
Translate howto (on example of russian translation - language code is "ru")
We will need: Java and Apk manager
Download Java from the developer site, that is
or
Apk manager is available for download
Make sure that everything is set up. All events will take place in the folder where you unzipped Apk Manager!
1) Copy the necessary application to the folder "\place-apk-here-for-modding"
2) Run Script.bat, enter the number desired application and press Enter
3) There will be a lot of options, do not worry, select item 9 (decompilation) and minimize (do not close!) command line window after that.
4) Go to the folder "\projects" and find the folder with the desired application.
Go to the folder "projects\Your_application.apk\res\values" ​​and look for the file strings.xml
Create a folder "projects\Your_application.apk\res\values-ru" and put the copy of strings.xml there. "ru" must be changed on your language code (it for Italian, for example).
Edit strings.xml and save it in UTF-8 encoding.
5) After editing maximize Apk Manager window and select item 11.
On question about system app creation, answer n (No).
6) Now we have to sign the application, everything is simple. Choose 12.
7) 24-exit
Translated application will be located at "/place-apk-here-for-modding/signedYour_application.apk"
Try by youself. It's simple.
Guest giz
honoraty seweryny tomasza - it's a name-days in Poland for today.
If you decompile APK, you can find it in java script and eliminate.
Unfortunately, I haven't time enough for that.
Guest Sander
Tested on ICS.
Thanks for you're efforts! However and maybe i am a noob
/emoticons/default_wink.png" alt=";)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />. I downloaded you're file, copy the file to the android phone. App works well but is in polish. How can I get it to use the right XML language file?
Guest giz
Please, uninstall previous app, then install new app.
Language will be choosen automaticaly.
No Polish in translated APK at all, You simply cannot make mistake
Guest dsilletti
Good job giz!!!
I Will post an updated Italian file, anyway it works perfectly!!!
Unfortunately with new HC2 beta version 3.x the app doesn't work, but with version 1.x is perfect!!!
Merry Christmas!!!!!
Guest giz
dsilletti
You can recompile APK by yourself, use instruction from my 21 December post
Guest skyhooper
Hi there the French apk for Fibaro1.0.10Beta is ok.
you can have it here.
desolé pour les accents
Guest skyhooper
Hi again
Have 5 minutes to do the italian xml for dsilletti
this apk is RU,IT,FR
Merry Christmas
Joyeux Noël
Guest MarcelK
And here is the one including a dutch translation.
It contains:
* et
* it
* nl
* ru
And here is one including a swedish translation.
It contains:
* et
* it
* nl
* ru
* sv
Guest thales almeida
Hi guys, someone have tested the android app with the Beta firmware 3.341?I can't make it works. Thanks
Guest dsilletti
Doesn't work with beta 3
dsilletti, it's work, try uninstall app and install again in version 1.10, enter login, address and password again.
please remember that on beta not working remote
Guest dsilletti
Android App 1.0.10 beta doesn't work with HC2 v3 beta even after reinstall the apk. I have an error message when I press "Update Configuration" button on the phone: "Connection error ERROR: Invalid int: '21.62' " where 21.62 (that isn't an int) is the temperature of my room measured by fibaro universal sensor.
This is the error log from phone:
Regards
Hello dsilletti, is your phone connected with local network via wifi? With beta v.3 you can only get access if your phone is in local network(Your home local network, where hc2 is connected as well). Remote function - outside the house - do not work with beta at the moment.
Guest dsilletti
Of course, in local with WiFi.
As you can see from my post, the app connect to the HC2, but I've got an error regarding the temperature, that fibaro app expects as an integer, instead is a decimal number, so the app stops working
