Hello.
Is it possible to have a list with 100% fully tested and compatible z-eave devices for HC2?
So it can be possible to start working with HC2 without the risk of buying z-wave devices not supported.
Thank you very much!
Mario
Guest Maarten
Yeah, would like that too. Too much stuff I have is not or not fully supported (yet), which is a bit frustrating sometimes.
Guest FibaroKK
Agree, I look forward to see what devices work with HC2
Guest ericf
Aslo,
when one is not yet supported but a HC2 customer try to install/use one, they should provide support/advice and include in a patch.
For that the upgrade/new release should be for new functionality/stability/bug fixe but some other type of patch should be available --> like supported z-wave --> so it could/should be delivered related to new Z-wave element, customer needs (faster update cycle, less impact as a complete upgrade, faster upgrade window, most up-to-date Z-wave box ... this is very important for user when they look to by one, ... which one is the most aware about the last modules and also that support the largest list
/emoticons/default_icon_smile.gif" alt=":-)" /> )
Regards
  • 3 months later...
Sounds like a case for a user generated Wiki listing what kit they have and what isn't working on it maybe as notes?
  • 3 weeks later...
Guest jeromefr28
no news? no response to Fibaro ?
/emoticons/default_icon_confused.gif" alt=":-?" />
Dear Members,
We're working on such lists. I hope it will be published soon
Guest jeromefr28
here is my small contribution :
Siren and Strobe lights - SSA1 or SSA2 Fortrezz -> OK (recognize as a dimmer but OK)
Motion Sensor + Light Sensor + Temperature sensor - EZmotion 3 in 1 Express controls -> OK
Contact Detector - hsm02 Everspring ->OK
Contact Detector - SM103 Everspring -> OK
Fibaro Roller Shutter FGR221 V1.6 in bistable mode ->OK
with Fibaro Home Center 2 V1.033
Guest Kuuno
software 1.033
extra to previous list:
all fibaro modules
danfoss living connect thermostat
eversping water sensor
aenlabs door/window sensor
Guest jeromefr28
water and freez alarm sensor - WWA-02 Fortrezz -> ?
/emoticons/default_icon_question.gif" alt=":?:" />
motion detector - Everspring SP814 -> ?
motion detector - Everspring SP103 -> ?
smoke detector - Everspring SF812 -> ?
remote control - Minimote Aeon Labs -> ?
motion sensor, temperature sensor, humidity sensor and lighting sensor - multisensor Aeon Labs -> ?
Energy meter Aeon Labs -> ?
Smart Energy Aeon Labs -> ?
text to speech, speech recognition, webcam and RFID - Karotz -> ?
  • 3 months later...
Dear Members,
Hi Krystian,
Is there any update on this list?
Hi Fibaro support team
Please at least we need the list for supported devices
/emoticons/default_icon_redface.gif" alt=":oops:" /> I feel like I am stuck with your HC2 gateway limitations and lack of support.
I am really thinking to switch to another gateway. I heard that HC2 is the only gateway with lack of support.
I need to buy Z-Wave devices for my home, and I am not sure which is supported and which is not
/emoticons/default_icon_evil.gif" alt=":evil:" />
Guest MitchellOnline
How about the Aeon 4-in-1 multi-sensor?
See
See
Detects ok, but only as a motion sensor.
@Fibaro - will this device be compatible soon?
QUEES RETO Plug-in Switch Plus -> OK (fully functional)
QUEES RETO Plug-in Dimmer Plus -> OK(fully functional)
QUEES RETO Shell Switch Plus -> OK(fully functional)
QUEES RETO Shell Dimmer Plus -> OK(fully functional)
review on
See
Are you sure about this? I phoned a Fibaro Reseller store about it, and they say the Aeon 4-in-1 multi-sensor should be full compatible.
I want to buy 8 of this device, but I need to be really sure this device is full supported by the Home Center 2, and not only motion!
I can only comment on my experience (1.037). Does this help
I actually started a seperate thread about this sensor earlier today
. I'm not sure I am the only one having trouble getting it to work for the other 3 functions
Thanks for your reaction!
It's crazy Home Center 2 doesn't fully support this sensor. Hopefully Fibaro will support it within the next firmware update, because many people are stuck with this sensor!
/emoticons/default_icon_exclaim.gif" alt=":!:" />
Hello, Fibaro will come out also with they own multisensor, which looks great and very "expensive". Have a look here
I hope they will make 4-1 aeon sensor also compatible with Fibaro.
