Hi !
I can't find the list of tested and approved devices from FIBARO, where can i find it ??
Br// PEWI
Guest jrkalf
It would be great to have such a list in a wiki format. It'll allow people to maintain a list and have a page for each individual item for detailed information / configuration of special settings.
I'm not sure we'll ever see a Fibaro endorsed list of other manufacturer's devices. It would not be in their interest. However, you're probably asking for just a list of what the community has found to be working.
So, Fibaro devices aside, I have a mix of partially working devices and non working devices (won't support COMMAND_CLASS_BASIC). Does anyone have a fully functional (associations, parameters, etc) non-Fibaro device?
Guest hotrot_net
According to SQL DB 1.044 by Fibaro this is what has to work. See Fibaro that wasn't so hard to come up with.!!
Mind you that this list doen't say that all is fully functional it only says that its listed in the SQL that HC2 uses.
Fibaro
FGD211 DIMMER V1.0 - v1.9
FGR221 Roller Shutter V1.0 - v1.9
FGS211 Switch ON OFF 3kW V1.0 - V1.9
FGS221 Switch ON OFF 2x1,5kW v1.0 - V1.9
FGD211 V1.10 DIMMER 60Hz
FGR221 V1.0s Roller Shutter
Everspring
ST814 Temperature / Humidity Detector
ST815 Illumination Detector
ST812 Flood Detector
SP103 PIR Detector
SM103 Door/Window Detector
AN157 ON/Off Plug
SE812 Indoor Siren
SF812-1 Smoke Sensor
HAN01-1
HAN02-1
SP814 Motion detector
Aeon Labs
Door/Window Sensor
DSB05xxx-ZWUS Z-Wave Multi Sensor
Horstmann HRT4-ZW
Horstmann HRT4 ASR-ZW
EZMotion 3 in 1
Hortsmann AS2-RF
Wintop iAlarm 1184R-FR
TSE03 Door Bell Everspring
Fortrezz WWA-02
RETO Plug-in Switch - Plus QEES
RETO Shell Switch - Plus
AN145 Screw-in on/off module
HSM02-1-1V1 Mini Door/Window Sensor
Everst HSP02 -1-1V1 Motion Sensor
Merten/Schneider
507502 Switch Merten/Schneider Electric
MEG5016-0002 Merten/Schneider Electric
507219 Merten/Schneider Electric
Danfoss
Danfoss Living Connect Thermostat
Danfoss Living Connect Thermostat V2.0
Danfoss Living Connect Thermostat V2.5
  • 3 months later...
Guest jrkalf
Sorry Admins,
Forums Archeology going on here:
Fibaro, could you make a page under the www.fibaro.com support page with a HCL (Hardware Compatibility List)? Devices that have been tested and verified as working.
We all know that Z-wave is a protocol and if you can pair a device, it's supposed to work. Sadly the HC2 doesn't have a template for all devices. Eventually it'll get a template for everything if users keep submitting new hardware to Fibaro and open up their HC2 for development / research purposes.
Could you please make a HCL list with devices that you have build templates for and which are working in HC2, verified. This could be a link under the support page of Fibaro or make it a section on a wiki that Fibaro could put up.
Having a wiki would give Fibaro immense powers to harvest information from it's userbase and have the end-users help build the Fibaro supported device documentation, issues and solutions.
reason I got here? I was looking for support for the Everspring SP814 ... which wasn't to be found on any other fibaro page
/emoticons/default_icon_confused.gif" alt=":-?" />
jrkalf,
My SP814 Motion detector is working fine for me.
Dear Members,
We're working on such lists. I hope it will be published soon
Dear Krystian,
We are still waiting for such lists (9 months later). Would it be possible to publish them soon?
Thank you.
Guys,
Are you still looking for a list of compatible devices?
At Vesternet we are working on a list of Z-Wave devices that work with the controllers we sell, including the HC2. This will not be a comprehensive list, it will focus on the most common products used by our customers.
But it would help choosing sensors and other devices to work with the HC2.
I am looking for a small number of beta reviewers to check the list and page during this week. If you would like to help please send me a direct message.
Guest mhn
Hi monions.
We danes started this list a long time ago (long before HC2) maybe you can use some of the info via google translate?
Regards
Morten
Hi Morten,
Thanks for the link, that looks really useful.
I'll let people know when our version is available.
  • 1 month later...
Our full list has been published at
Any updates, suggestion or changes are always welcome.
Guest jrkalf
Suggestion is to pull the . from the link above
that works a bit better.
Nice list, it's not an exhaustive list of all devices, but it's a good start.
Thanks!
Thanks for the correction, not sure how the . got into the link.
Correct link is
thx for info about HSP02 and SP814 we know (we got them on list to do) but for me interesting is problem with AEO-HEM2, HEM3 anyone can confirm that? if yes please tell us a firmware version of that device (maybe that is a problem)
Thanks for the note on the HEM2/3.
We've done some further testing and can confirm that this device does work great in the HC2, including the Energy panel. This was tested with v3.548.
The Z-Wave compatibility guide has been updated.
Please let me know when you have an update on the Everspring sensor issues, we can update the guide and also inform customers.
