Change Log for Software Updates
For those that continue to request this thread, I will continue to post the update logs in this conversation. Please try to keep comments to a minimum so we can use this thread for its purpose (finding information on what changes happened in each version)
Software Changes List 1.032:
- Fixed devices connections screen
- Added possibility to change and upload scenes icons
- Adaptation to work with new Fibaro HC2 app for iPhone
- Lighter data requests for iPhone app
- Bug fixes
    Software Changes List 1.047:
    - Fixed ST814 reporting bug, which could in some cases report humidity in temperature endpoint and report temperature in humidity endpoint
    - Fixed Event Panel
    - Added support for Fibaro v2.1 devices
    - Added support for Danfoss v2.51
    Beta software changes list 3.423:
    This version is the final beta version and will be transformed into stable version.
    WARNING!
    Upgrade to Beta software cannot be reversed by standard software upgrade procedure. The only way to come back to official software is to use Recovery Mode, then use backup and upgrade to official software version. It is highly recommended to create backup file before attempting to install Beta software.
    After update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
    WARNING! In case of update from old, official version (v1.x), after that update all users will be deleted. Admin password will be reset.
    This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).
    If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start.
    3.423:
    Added:
    - Helios intercom support
    - VoIP panel
    - Devices notifications
    - Information top bar and Dashboard - subpage with configurable information views
    - New drenchers panel
    - Views from cameras in Your Home section
    - Possibility to manually add theoretical power consumption for devices not supporting power metering, visible in Energy Panel too
    - Support for new device types, new device parameters
    - Remote access through iOS app
    - Scene conversion during update from old version
    - Enumeration variables
    - Other minor system elements
    Fixed:
    - System stability
    - Scenes: Lua code generation, timers handling, variables handling, multilanguage
    - Leds working in HC2
    - Device parameters
    - Location settings conversion during update from old version
    - Virtual devices buttons conversion during update from old version
    - Other minor bugs reported by customers
    WARNING! In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.
    3.545:
    - Fixed displaying image from Home Entry System Helios.
    3.544:
    - Possibility to run scenes by Lili (please reload Lili database in configuration after update).
    - Remote access scripts watchdog added.
    - Added possibility to choose triggers in block scenes.
    Bugtracker tickets:
    - 0000487: Add/Delete GPS Points Error.
    - 0000480: GPS condition doesn't work.
    - 0000476: Panel ogrzewania przestaje.
    - 0000460: Heating Linked Device fails to switch off Switch 2 (a.socha) - rozwiązany.
    - 0000459: Modified variables don't show up in scenes.
    - 0000454: Variables with space can't be changed.
    - 0000437: EnergyPanel date select.
    - 0000426: Option to deactivate variables as scene trigers
    - 0000424: Bad slider position (cosmetic) in dashboard / actuator panel.
    - 0000418: Błędne przekierowanie w trakcie tworzenia scen opartych na pozycji GPS.
    - 0000403: headline.png not found in linked device panel (head of menu).
    - 0000402: Unable to save new state of predefined variable value in dedicated panel.
    - 0000396: Belka nazwy panelu domofonu.
    - 0000387: Impossible to access the HC2 web page from iPad.
    - 0000380: On the HRT4-ZW the temperature reading is being used as an energy reading.
    - 0000369: Translation needed: Home Entry System Panel.
    - 0000350: uprawnienia użytkownika.
    - 0000341: Bad energy costs in energy panel header when switching from power usage to energy costs.
    - 0000331: Temp value of HRT4-ZW as energy usage in bar and panel.
    - 0000328: Camera Panel when "Remote Access" is selected
    - 0000288: SOme scenes can't be saved and disappear.
    - 0000274: Modular Alarm Panel - iOs control and Users.
    - 0000268: Modular Alarm devices can no longer be selected in Scenes.
    - 0000245: no keyboard editting lua scripts via the iPad.
    3.517:
    - New, quicker and future oriented system architecture.
    - Rebuilded, faster configuration interface.
    - Faster communication within Z-Wave network. Faster system reaction for devices states changes.
    - Improved, much quicker sending commands to devices via the iOS application.
    - Quicker scenes execution.
    - Added support and debugging for Lua scripts.
    - Automatic conversion from graphic block scenes to Lua scripts.
    - Added possibility for Lua debugging.
    - Sending sms/email/push notification from scenes.
    - Integration with Satel alarm.
    - Added support for new device types.
    - Energy panel and managing devices with energy measurement.
    - New, extended mobile interfaces.
    - Power consumption options in block scenes.
    - Additional options in video cameras.
    - Z-Wave tab in configuration.
    - New device inclusion window, informing user of new device configuration stages.
    - VoIP panel
    - Support for new device types, new device parameters.
    - Modified scenes main screen.
    - New Virtual Devices version - now you can add a button or slider executing Lua script.
    - Changed configuration interface layout
    - Moreover 3000 minor bug fixes and improvements.
