Home Centre 2 Virtual Device to Wake PC (WOL)
Guest Singapore
Is there any way to wake up a PC using WOL - Wakeup on LAN?
Guest deraaij
    No changes I'm afraid...
    [ERROR] 18:47:51: line 6: unexpected symbol near '
    Strange for me it works, I also not have a ' character.
    Guest Cirion
    This would be very useful for me. All TV's in my house run a small PC with XBMC. Would be great to be able to make a sceene that dims the lights, shuts the blinds and turns on my XBMC wich in turn turns on the TV at the correct input (using HDMI CEC adapter).
    I don't know if the HC2 can send packet over UDP, I think support only TCP in virtual device at this time, perhaps in V3 ? With help of LUA ? WOL use Broadcast over UDP to send magic packet ...
    I can include this fonctionality in the HC2 SDK (
    ) and provide a way to do this: for example call a script wol.ashx?mac=XxXxXxXxXxXx !
    Regards.
    Guest Fidziu
    Krikroff,
    LUA will be added to virtual devices with http and udp support.
    Wake On Lan works perfectly in that solution:)
    Guest deraaij
    Krikroff,
    Wow! Just what I was hoping/waiting for!!!
    Will it also have a binary button? (On/off so we could toggle it from external resources and run scenes based on it)
    Mark
    Guest deraaij
    For now there is a workaround
    Once do the following command via a scene:
    After that you can do:
    (Change: 6c:f0:49:1a:61:3a to the correct MAC address, you could also use a variable)
    Wakes up my HTPC like a charm
    I'm à new fibaro user, how do i get the commando's in to a scène ?
    Guest deraaij
    Hi Welcome!
    You should switch the scene to LUA (only possible in the Beta version).
    Mark
    hmmmm,
    I think i'll wil wait for the next firmware, just don't wanna run beta versions
    /emoticons/default_laugh.png" alt=":lol:" />
    The function with os.execute is not possible after latest Beta updates, am i right?
    Is there any new solution to run wake on lan?
    Guest deraaij
    Use LUA in a virtual device:
    Damn your good
    I've this code after changing the mac adress and ip but it does not works...
    Guest deraaij
    for me it works, strange ?
    Edit: Just to be sure I tested it for you, but it works like charm
    [ Added: 2013-03-14, 23:37 ]
    BTW you should only change the Mac address.
    greeeeeeaaattttttt it works only with mac adress changing
    Guest deraaij
    Guest sk8er000
    good job!
    I suggest to add a guide section with some of this scripts to help users with most common LUA scripts
    Does this still work whit the new beta version ?
    i tryed it but it does not work ?
    Guest deraaij
    The LUA variant works still for me (so the one without os.execute)
    Oops
    /emoticons/default_icon_redface.gif" alt=":oops:" /> my bad
    the problem was between the keyboard and chair.
    Made an typo in the mac addres
    works like a charm
