Home Centre 2 Virtual Device to Wake PC (WOL)
Guest Singapore
Is there any way to wake up a PC using WOL - Wakeup on LAN?
Guest deraaij
    Oops
    /emoticons/default_icon_redface.gif" alt=":oops:" /> my bad
    the problem was between the keyboard and chair.
    Made an typo in the mac addres
    works like a charm
    Good to know!
    Hello!
    Can you please tell me, what:
    [ERROR] 18:47:51: line 6: unexpected symbol near '
    mean?
    Should I type in my iMac hardware MAC, or it's wi-fi's?
    Greetings Vect0r.
    Guest deraaij
    Hello!
    mean?
    Greetings Vect0r.
    Can you post your code?
    Sure, sorry...
    magicPacket = string.char(0xff, 0xff, 0xff, 0xff, 0xff, 0xff)
    macAddress = string.char(0x6c, 0xf0, 0x49, 0x1a, 0x61, 0x3a)
    for i=1, 16
    do
    magicPacket = magicPacket .. 00:22:41:f9:f1:44
    socket = Net.FUdpSocket()
    socket:setBroadcast(true)
    bytes, errorCode = socket:write(magicPacket, "255.255.255.255", 9)
    if errorCode == 0
    then
    -- printing log under virtual device
    fibaro:log("transfer OK")
    else
    fibaro:log("transfer failed")
    This contains an airport express MAC adress.
    vect0r, try my script, replace with your mac address and fun...
    Guest deraaij
    Sure, sorry...
    for i=1, 16
    do
    if errorCode == 0
    then
    else
    Following also works:
    No changes I'm afraid...
    Guest skeal
    works like a charme! thank you
    wouldnt :-
    need to be
    magicPacket = magicPacket .. "00:22:41:f9:f1:44"
    Guest deraaij
    tha's why I use: magicPacket = magicPacket .. macAddress
    Thank you for sharing. I tried it, but something is wrong in my setup.
    I get the following error:
    [ERROR] 11:38:14: line 11: bad argument #1 to 'char' (number expected, got nil)
    This refers to the line:
    x = x .. string.char(tonumber(string.sub(s, i, i+1), 16));
    What is going wrong?
    hvb83, this is probably a problem with ctrl+c / ctrl+v, copy and paste on text edit, check the scipt and put it in HC2... Regards.
    Use LUA in a virtual device:
    Thank you work very well
    It does not work. The computer wakes up from sleep only, but not when it is turned off. In contrast, the script in general it does not turn off or fall asleep.
    "WAKE ON LAN" not ressurect-from-the-dead-on-LAN
    /emoticons/default_icon_wink.gif" alt=";-)" /> For your PC to wake up, it must still be listening on LAN. If it was powered off, this would not be possible unless it takes power from the LAN, and then it isn't really powered off anyway is it?
    Wake on LAN can wake up also computer that has been completely shut down. It needs support for that from NIC and BIOS.
    PC is actually always powered up, unless hardware switch has been turned off or power cable has been detached. After normal shutdown the mainboard is still powered and alive.
    How could this be modified to automatically wake up a server every morning at 6:00?
    Same script, other MAC.
