1.041 Update
1.041 is out ! 2 update in less than a month, good news for us ...
Download is in progress and it seems take a long time...
  • Answers 72
  • Created
  • Last Reply
My hc2 response upgrade error 9.
please do update again
response error 8
i have try to recovery but no updato to 1-09
Guest fab971
My box doesn't propose to update (v1.038). how to get an update?
    I have send you a screenshot ...
    Have you try to reboot your box ?
    Guest fab971
    Several times. I had not seen other updates.(v1.040 for example)
    please do first update to 1.040 and later you will see 1.041 update, HC2 got access to Internet?
    response error 8
    try download update again, error 8 = bad checksum please do update again, after success you will have on recovery version 1.038
    Guest fab971
    I don't see 1.040 update!!!
    Most of the nodes are dead... and they are already dead for 8 hours now... how do you fix that?
    I installed the update, no problems at all.. only the minimote is universal sensor now
    /emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> I will try to delete and add it again in the evening.
    fab971, how many LEDs working from right?
    Guest fab971
    3 LEDs working from right.
    fab971, port 22 is open?
    The update to 1,41 from1,40 not function , i restored to 1,009 but the banner update not appeared
    No problem with update so far, took about 15 minutes to update
    First attempt took took close to an hour and then came up with some fatalfileerror message. Second attempt was quick although it came up with a
    "Upgrade Error: 27"
    Hi Fibaro, can you publish a list of error messages, we can more easily understand what is happening and not wait hours, please
    Even though my updated failed, all my Vitrum slave light switches have morphed into:
    FGBS321 Universal Binary Sensor V 2.1 US
    Beforehand, it knew them as light switches, correctly.
    davedotnet, to fix it you must remove and add again devices
