Beta API - http Commands (3.341)
Guest deraaij
Hi all,
Just to share for those who did not figure it out already, the following http commands work with the beta version:
Devices:
ID = device ID
name = action
arg1 = (e.g. value dimmer)
http:///api/callAction?deviceID=4&name=turnOff
http:///api/callAction?deviceID=7&name=setValue&arg1=39
Virtual Devices
ID = device ID
arg1 = button ID
arg2 = slider value (only for slider)
http:///api/callAction?deviceID=15&name=pressButton&arg1=2
http:///api/callAction?deviceID=51&name=setSlider&arg1=8&arg2=30
Notification
ID = Device (Iphone, e-mail et cetera)
arg1 = Notification template
http:///api/callActiondeviceID=9&name=sendDefinedPushNotification&arg1=1
Arm/Disarm devices
arg1 = 1 - Armed
arg1 = 0 - Disarmed
http:///api/callAction?deviceID=51&&name=setArmed&arg1=0
Scene
ID = SceneID
http:///api/sceneControl?id=14&action=start
http:///api/sceneControl?id=14&action=stop
Get json status from api:
http:///api/rooms
http:///api/scenes
http:///api/devices
http:///api/devices?id=316 # Specific value of a device
http:///api/virtualDevices
http:///api/globalVariables
http:///api/weather
http:///api/sections
http:///api/users
http:///api/energy/now-3600/now/single/devices/power/58
Updates used by mobile:
http:///api/mobile/interface/refreshStates?last=3058
Reboot:
Post --> http:///api/settings/reboot
etc.
change variabele example:
Unfortunately will not trigger scene (yet):
Mark
jcs10,
in LUA:
Local temp = fibaro:getValue(28, "Value")
richo, fibaro:getType(); is fixed in next version for scenes
Guest jcs10
    Thanx for the answers, but... it's to create some graphs from my temp sensor.
    Guest deraaij
    Added example api to device enrgy panel (http:///api/energy/now-3600/now/single/devices/power/58)
    I try to integrate new API HC2 in a IOS remote application called Roomie for lightning control witin the Roomie app. In the old API there were no problem with the http commands, i just added the correct IP address and used port 80. But now with the new API and new commands i only get HTTP/1.1 401 Unauthorized. What am i missing? is there an other port that needs to be used?
    Any help appreciated!
    Guest deraaij
    You have to use the user and password in the url, like this:
    Thank you Mark!! Now it works perfectly!
    curl -X PUT -d '{"name": "Test", "value": "122"}'
    Does that working ???
    Edit: Yes it is working ^^
    Guest deraaij
    There is only a bug (logged in bugzilla) that a scene will not be triggered by a value change, it will however work in scene's where it is not used as a trigger.
    I know, I only want to update the value for xbmc, to have the ID off the movie we are watching.
    Guest thales almeida
    Hi guys, on the 1.xx firmware, I used to send commands to Fibaro, via Redeye (IR controller), but on the redeye interface we need to inform the IP in one box, and the message on another one, and we are not able to put user:password@ip on the IP box, so the authentication never work. Is there another way to send this authentication? tks
    thales almeida, give more details what you can send
    can you send GET url?
    Fibaro, is the Virtual device also available through a json request?
    *UPDATE: already got it
    @Adv.Usr.deraaij could you update your first post with:
    Guest Martial25
    Do you have examples of API with the energy panel.
    I would like to retrieve the set of values ​​to graphs (live, day, month, year)
    Thank you in advance
    Regards
    Martial
    Guest deraaij
    Done.
    [ Added: 2013-03-29, 21:25 ]
    Regards
    Martial
    I will have a look for you, unfortunately I have some issues now which prevent me from checking it directly ....
    In virtual devices only the first 4 buttons will send http commands.
    This command will work in button 1 not in 5 and up
    -- Setting up the connection data
    domation = Net.FHttp("192.168.1.41", 80)
    response = domation:GET("/index.php?color=red")
    fibaro:log(response);
    Button numbers will count further even when an earlier number is deleted.
    I have now button 1-4 and then 9 and 10.
    Ex: We put the fibaro IP on a box and the command on a script page:
    IP: 192.168.1.180 (Our HC2 IP)
    Scripting.SendHttpMessage("fibaro/externalRequest.php?id=setDimmableLight&deviceID=34&value=100")
    But now, we need to put that header on the message, and there isn’t a place to put it.
    What we need to know is if there is another way to send this authorization, maybe on the message, but not on the header. Something like this…
    Ex:
    IP:192.168.1.180
    Scripting.SendHttpMessage("api/callAction?deviceID=7&name=setValue&arg1=39user:password”)
    Thank you for your attention .
    Update:
    Problem is only when buttons are removed.
    New created virtual devices will work fine also for button's 5 and Up
    Is it possible to access all events through the HTTP API (from the Event Panel)?
    dvalfrid, yes
    date as timestamp
    example
