Beta API - http Commands (3.341)
Guest deraaij
Hi all,
Just to share for those who did not figure it out already, the following http commands work with the beta version:
Devices:
ID = device ID
name = action
arg1 = (e.g. value dimmer)
http:///api/callAction?deviceID=4&name=turnOff
http:///api/callAction?deviceID=7&name=setValue&arg1=39
Virtual Devices
ID = device ID
arg1 = button ID
arg2 = slider value (only for slider)
http:///api/callAction?deviceID=15&name=pressButton&arg1=2
http:///api/callAction?deviceID=51&name=setSlider&arg1=8&arg2=30
Notification
ID = Device (Iphone, e-mail et cetera)
arg1 = Notification template
http:///api/callActiondeviceID=9&name=sendDefinedPushNotification&arg1=1
Arm/Disarm devices
arg1 = 1 - Armed
arg1 = 0 - Disarmed
http:///api/callAction?deviceID=51&&name=setArmed&arg1=0
Scene
ID = SceneID
http:///api/sceneControl?id=14&action=start
http:///api/sceneControl?id=14&action=stop
Get json status from api:
http:///api/rooms
http:///api/scenes
http:///api/devices
http:///api/devices?id=316 # Specific value of a device
http:///api/virtualDevices
http:///api/globalVariables
http:///api/weather
http:///api/sections
http:///api/users
http:///api/energy/now-3600/now/single/devices/power/58
Updates used by mobile:
http:///api/mobile/interface/refreshStates?last=3058
Reboot:
Post --> http:///api/settings/reboot
etc.
change variabele example:
Unfortunately will not trigger scene (yet):
Mark
Guest GrZeCh
    does someone know how to create new globalVariable using API?
    I've tried:
    but it just don't add anything (it is also not returning any error).
    Regards
    EDIT: Ok. I've managed to add normal variable using:
    Now I only want to change this variable to predefined variable with 0 and 1 options.
    EDIT2: Ok. To add new variable you must perform mentioned POST and then perform update command:
    It is possible to activate/Deactivate manual mode in heating panel with lua or http command?
    My goal is to cut my heating with remote (minimote)
    thx
    SATEL Basic Control
    To arm:
    @/api/callAction?deviceID=&name=arm
    To Disarm
    @/api/callAction?deviceID=&name=disarm
    To Disarm if Siren is activated
    @/api/callAction?deviceID=&name=clearAlarm
    Must be followed by disarm action or Siren will be deactivated and alarm will stay armed - Useful for turning off siren but allowing for breach detection to remain
    Arm or disarm any device:
    arg1 = 1 - Armed
    arg1 = 0 - Disarmed
    Could you add this to the first post?
    Guest deraaij
    arg1 = 1 - Armed
    arg1 = 0 - Disarmed
    Done, thnx!
    How can i set the longitude an latitude for a user through the Api?
    should be something like that right?
    that will not be that easy but it is posible
    for weather (sunset/sunrise)
    for user position, users are like devices so you can check them in
    example for admin
    you will get
    Yes I already saw that, but I want to set the location of a user. Instead of reading it. Any ideas?
    but what effect you want get? to get point on map in family panel? or in api/devices only change actual position user?
    I am working on a windows phone app. I want to set the location of a user. The same as that Iphone and Android do. So yes in the Family panel and the actual
    stevenvd,
    /emoticons/default_sad.png" alt=":(" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20"> that part we don't have in api
    mh... so how do the android and Iphone do it?
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    Also not just setting the current location of the user? that should be quite easy.
    they not using api to do that, but if more people will want that we will add that action in api
    I prefer app for windows phone
    +1 for the api and the app
    Yes please
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> It would be great to be able to use an API to set user GPS position via 3rd party app (like Tasker app for Android).
    Then, I would also be interested to be able to use the API to set the GPS position refresh rate of the Fibaro App. For example : as long as I am located more than 20km away from home, I would like to have a 10min refresh rate, but then , if I am less then 20 km away from home, I would like to have my GPS position refreshed every single minute.
    Thanks and keep up the good work !
    I can't seem to get or set the Global Variables through the API.
    Trying
    Does not do anything.
    Most important is setting it!
    Can someone help me? Because than I got a solution for the Windows Phone Locations....
    [ Added: 2013-08-18, 18:07 ]
    Oke, got everything ready. if someone could help me with how to set a global variable through the API. I have the Location based on Windows Phone working.
    I am also working on Notifications, need some more time for that as I need to run a Service on my server (As I can't use the Home Center for this yet)
    Furthermore is the Speech for Lili also almost finished
    [ Added: 2013-08-19, 09:57 ]
    ah, so the
    is working again after restarting the HC2. Still no option to set it though
    A. socha, any possible option for this?
    [ Added: 2013-08-20, 21:42 ]
    Seriously no one knows this? or is it just not possible?
    I would like to change value of my varible with API command it is possible ? (like this
    No, try that:
    Not works
    The url works but the value are unchanged
