GreenWave Reality PowerNode
Guest deraaij
Hi Fibaro,
the good news, It is recognized by fibaro HC2. It sees a root with 6 childs. Unfortunately it only shows overall power usage on the root and not on the outlets itself. I hope you can have a look at it. it's a nice power strip with 6 outlets!
It is perfect for measuring multiple devices. If you need some info let me know.
You can buy it here:
Mark
  • Replies 46
  • Created
  • Last Reply
Top Posters In This Topic
Guest deraaij
    Btw I checked, as reference, it works with homeseer and openzwave.
    Mark
    Guest deraaij
    Some additonal info:
    in the log i see:
    12:41:52:416151 [Notice] ZW_STATUS: MeterType : 33 MeterSize: 4 MeterPrecision: 1
    12:41:52:416475 [Notice] ZW_STATUS: POWER Report: 634.7 W
    12:41:52:416644 [information] ZW_DEVICE: GENERIC TYPE SENSOR: 37
    12:41:52:417067 [information] ZW_DEVICE: EvnetSensorValue: 634.7 PK Device: 60 Unit: W
    12:41:52:417474 [information] EVENT: valueSensor: PK Device: 60 Value: 634.7 SENT
    12:41:52:422307 [information] EVENT: unitSensor: PK Device: 60 unitSensor: W SENT
    Device 60 is a child so it looks if it receives the usage correctly.
    Let me know if i can help with some additional info.
    Guest deraaij
    Hi Fibaro,
    I have done a bit more research, with some insert's in some tables it works like a charm, so it it should be an easy fix!!
    Mark
    Strange things do happen... a multi instance device that homeseer likes. Have you actually tried it yourself?
    /emoticons/default_icon_confused.gif" alt=":-?" />
    Sounds like an interesting device but I have not found where they are for sale for UK. Where did you manage to get it? It would be really useful in my setup.
    Robert
    Guest deraaij
    Robert
    I added a link in my first post. After the inserts i mentioned in my previous post it works like a charm with HC2!
    Mark
    Guest deraaij
    Sorry obviously you want a UK plug
    I saw thisL
    so they exist for uk as well you would think.....
    Mark
    Guest deraaij
    Fibaro,
    Do I need to test/ give any additional info?
    Code:
    tabel: NEW_Property
    INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','valueSensor','0','CURRENT_TIMESTAMP');
    INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','unitSensor','W','CURRENT_TIMESTAMP');
    INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','valueMeter','0','CURRENT_TIMESTAMP');
    INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','unitMeter','kWh','CURRENT_TIMESTAMP');
    INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','meterSupport','{"vMeterSupport":[{"meterType":1,"sMeterType":"kWh","meterScale":0,"sMeterScale":"","value":0,"enable":true,"lastPolling":1358584209,"configuration":true,"retryConfig":0},{"meterType":1,"sMeterType":"W","meterScale":2,"sMeterScale":"","value":0,"enable":true,"lastPolling":1358584209,"configuration":true,"retryConfig":0}]}','CURRENT_TIMESTAMP');
    INSERT INTO "NEW_Property" ("Device_Id","Name","Value","Modification_Time") VALUES ('60','sensorSupport','','CURRENT_TIMESTAMP');
    table: NEW_Action
    INSERT INTO "NEW_Action" ("Device_Id","Name","Arg_Mask") VALUES ('60','resetMeter','1');
    Hi Fibaro,
    With a bit more information, the user community could start unravelling many other devices so that HC2 has even better support for z-wave devices.
    Could you create a sticky for posting this information so we can post all information for you and share with others.
    I have a Merten sensor that I am going to try to get working using the info Mark has posted.
    Can you help us build on Mark's great start please.
    regards,
    Robert
    Guest imparator
    Hi, de raaij
    Can you tell us how you get it work?
    I like this one
    If it works 100% I will also buy this one
    Guest deraaij
    Hi, de raaij
    I like this one
    I have not tested everything inside out but, out of the box you can turn on and off all six outlets.
    With the insert scripts stated in the previous post all outlets are recognized by fibaro with regard to energy consumption. I am using the current consumption to monitor if someone switch the media center (and pvr) from standby to on to trigger a scene which power the tv and receiver and set the correct channel / input and set the correct standard volume. I didn't check if the total consumption is perfect et cetera.
    Let me know what you want to know in order to make your decision and I will test it for you. BTW I am on the latest beta.
    Hi, de raaij
    I like this one
    Hello deraaij,
    I have 2 nuon powernodes 6 outlets. I like to try the insert scripts you have made. Can i just run the script within a virtual device?
    What do i have to do after the inserts? Do i have to reset the powernode?
    At this moment i'm using the latest beta.
    Out of the box it is possible to measure the total power using the energypanel. But is seems the energypanel is buggy. Sometimes i see when i switch on a 25 watt lamp 50 watt powerusage.
    Guest deraaij
    Hello deraaij,
    If you have SSH access you can use phpliteadmin (deploy the php file in var/www point to /opt/fibaro/ as the db dir) if not you can (for now in the current beta) use os.execute in a scene:
    os.execute('sqlite3 /opt/fibaro/db ""')
    or wait, because I hope with all the info Fibaro fix it in the next beta release, and you don't want to brick your box, be careful
    PS Don't forget the use the correct device id's. Reboot after the inserts.
    Mark[/b]
    Hoi Mark,
    Thanks for your help. I did not succeed yet but wil do some more tries in the weekend.
    Btw is the root password public available? Or did you get this privilege by fibaro.
    Guest deraaij
    Hoi Mark,
    No problem. Succes, let me know if you need help. With regard to root access, neither unfortunately but there are multiple ways to acquire it.
    Mark
    Guest deraaij
    Hi Fibaro,
    Do I need to test / give more details to help you support this device?
    Can anybody give me some hints how to root the HC2 so i can install phpliteadmin and insert the sql statements?
    I have inserted the sql insert statements and it now works like a charm
    • 2 months later...
    Now since fibaro has locked the possiblity to "root" our devices the easy way.. will they start help those out who havent hacked their hc2?
    When will this device start working as it should on our hc2's?
    • 3 weeks later...
