GreenWave Reality PowerNode
Guest jrkalf
    I have it working... The button "Reconfigure" I never noticed consiously. But once hit and set "Polling time interval" to 1 (presuming it is once per second) I can view live the consumption.
    I believe it is showing the consumption of all 6 outlets together, but I don't care as I can now trigger to turn on other devices which is simple now and automated.
    After hitting "Reconfigure", I can see other options like Calibration and Control Protection which settings doesn't effect at all.
    So ultimately, it would be nice if Fibaro just supports it. How easy it can be?
    That's the reason why I sent in the ticket.
    Currently I do get "kwh" usage (the blue numbers), but I don't get the active power draw from the system (the green numbers). It would be great to have it fully functional.
    regards,
    Jelle
    • Replies 46
    • Created
    • Last Reply
    Top Posters In This Topic
    hmm, maybe I don't understand fully...
    but when I click on the chart "Live" I see exactly the power consumption but also the "Current Energy Use" (above the meter) is correct.
    What do you mean with green numbers?
    When I use in LUA if (tonumber(fibaro:getValue(911, "valueSensor")) >= 14
    it checks if the power consumption is higher then 14 Watt and it turns on other devices as well. Works fine.
    However I have the feeling the power consumption of all 6 outlets is accumulated (I didn't check thoroughly, but I don't care)
    I would say to Fibaro: just support the full range of functionality! good that you have entered into bugzilla, I should do this as well as I have a long list of bugs (some of them very obvious to see/find, like integration of Satel alarm into Fibaro, inactive scenes that are still visible in iDevices etc... too many simple bugs that are easy to resolve I believe)
    This device looks really nice (if Fibaro manage to support it fully), a stupid question perhaps, but does it have Schuko outlets?
    (And it is sold on any site with european delivery?)
    It's a schuko outlet (according to wiki).
    By the way, is anyone noticing as well that the devices behave after I wake up the next morning that it is a dead node? I can see in the tekst message box (html page) the device (main number) is having problems saying "Sending error". Once I click on one of the 6 devices it is waken up....
    I reported a bug for random dead nodes. It has been acknowledged and they are working on it (issue 1005)
    I presume the random dead nodes is only applicable for the Greenwave PowerNode as I never have dead nodes for Fibaro devices...
    try set the refresh rate to 50 seconds. The led will stop blinking and it won't turn dead again...
    The power reading is only of the First outlet.
    Further it is quite sensative to interference. So if it goes dead, check any devices that are near (my mediacenter remote for instance) makes the nodes go dead..
    there have been many requests for fibaro to support the full functionality. So don't count on it
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> For me it works well atm
