1.047 Update
Dear Members,
Today we have released new software version.
Software Changes List 1.047:
WARNING! This update can last longer than previous updates because of downloading new Recovery Mode ver.
For correct display of the update progress, we recommend refreshing the page (CTRL+F5) before starting an update.
1.047:
- Fixed ST814 reporting bug, which could in some cases report humidity in temperature endpoint and report temperature in humidity endpoint
- Fixed Event Panel
- Added support for Fibaro v2.1 devices
- Added support for Danfoss v2.51
Since I upgraded to v1.047 I frequently have dead nodes (multiple FGS211). I didn't have any issue until v1.045. Not sure i've seen it with v1.046.
As these relay switches are used as protection for my electric floor heating (switch off above 28 degrees) it's very undesirable they fail! Last few days I noticed some floor mats were about 32 degrees without the relay switch killing power to it.
/emoticons/default_icon_evil.gif" alt=":evil:" /> This can cost me a lot if they got fried!
So Fibaro, is the dead node issue a known one?
    BvD, turn on Polling dead devices that may help you
    Just did. Hadn't seen that option before. Apparently added recently?
    Anyway, thanks for the tip! Let's see if my feet won't get baked anymore...
    1.047: Setting the danfoss valves in scenes to 0 seconds does not work, they always go to 2 hours, which is useless at night... Someone knows a hack for this?
    Manual mode doesnt work either for the danfoss valves
    I use danfoss with 1.047 version and works well. Danfoss are linked by zone in heating panel
    Does anyone use Danfoss thermostats far away from HC2 as well?
    Help Fibaro,
    Since I'm switched back from beta version 3.3.11 to offical version 1.045 I don't receive updates anymore.
    What's wrong and can you help me??
    Best regards
    Gerard
    PS.: When can we use the energy panel in the official version?
    Guest skyhooper
    You most switch to backup , return to 1.038 wait untile auto-update , update to 1.044 and 1.045 and so on...
    At the end put your owne last backup for 1.047 .
    Now you will have updates again .
    All your personnal icons will be gone.
    Hi Skyhooper,
    Many thanks.
    I will try it today
    Gerard
    Guest berga_s
    I use 2 DANFOSS LIVING CONNECT Z Firmware 2.51 (Fibaro show 2.5) since 3 weeks. I notice that some time (one per day or every two days) the Danfoss show the “no connection” alarm. I just need to run manually the procedure to check the link status and the alarm disappear.
    Right now I set the “vacation” in the heating panel, but only one Danfoss (the most far away from HC2) have received the command to low temperature.
